    Dismiss Notice
Island sink waste
Discussion in 'Plumbing and Central Heating' started by Suited72, 27 Aug 2015.
  1. Suited72
    Suited72
    15 Mar 2013
    43
    Thanks Received:
    3
    Leicestershire
    Country:
    I'm currently thinking of diy fitting a kitchen island with sink and dishwasher.
    The only thing that concerns me or that I can't understand is
    How to fit the 2 x 40mm waste pipes into the drain as they will be underground. The drain will likely be clay and I'm not sure of the proper connections?
  2. Can't help with the drain fittings but I think you will also have to consider venting in the sink waste. Someone may be able to advise more on that.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. Madrab
    Madrab
    4 Oct 2012
    8,214
    Thanks Received:
    2,339
    East Renfrewshire
    Country:
    • Thanks Thanks x 2
  5. Sponsored Links
  6. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,378
    Thanks Received:
    1,734
    Northamptonshire
    Country:
    Need to know what type of clayware you're faced with, then can advise on a suitable connection to the plastic fitting already shown, or if using new clayware drain, (Supersleve) then Hepworth will already make a suitable fitting to go on the end to allow connection of waste pipes.
  7. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
