Hey guys, i've taken a video of what's happening with our front door at the moment.
Basically, the door handle on the inside works fine, everything as normal. However, the outside handle works to lock and unlock, but when you try to use it to actually open the door, it doesn't do anything. To open the door you need to rotate the key a little bit more, which can start to hurt your fingers as it needs quite a bit of pressure.
Also, there is a small black knob you can just see at the top of the lock on the inside, is very stiff and only moves the latch a small amount...
Any thoughts of what might need doing?
