I'm looking for some advice on the following issue
Recently had a new composite front door installed. On initial inspection, the install was very good, and the installer was paid on the day.
The following day, I noticed that the door just didn't look right, it was almost as if it was lopsided.
I took some measurements, and there is a 2mm difference between the top and bottom of the door to where the glass cutout begins and whilst that doesn't sound a lot, it is noticeable to the naked eye particularly as the whole middle section of the door containing the glass appears be slightly tilted.
I brought this up with the installer who has contacted the manufacturer, at the moment, the manufacturer is saying that the difference is within the standard tolerances, but I can't believe that to be correct.
Here is a simple drawing of where the differences are to explain what I described above, can anyone comment on whether this is acceptable ?
note that the measurements are not the actual measurements, I can't remember exactly what those are, but the 2mm difference is accurate.
