Afternoon all,
I am about to renew my ensuite bathroom and although I have never tackled such a big plumbing job in one go I have done the odd bit of pipe laying and soldering over the years.
I mention this because I am fairly confident about giving it a go except for the fact that my central heating system has microbore pipe. I have never worked with it and so a little unsure what to expect.
I wish to replace the existing bathroom radiator with a towel rail.
My questions are as follows;
How do I attach the valves to the incoming pipe? can you buy valves suitable for 8mm pipe or do you have to buy reducer fittings from the standard 15mm in ports. Secondly the system is twenty years old and I am reluctant to bend the existing pipe too much, will it be brittle after this time and therefore not safe to manipulate. Thirdly is there anyway in which the pipe can be extended by jointing and if so would this be advisable (I assume new pipe will be more flexible??)
Sorry if this is so obvious, I just don't want to be caught out with a snapped pipe and no central heating.
By the way, the pipe is buried within the plaster, there is about 18" of pipe for each valve sticking out of the wall.
Any assistance in boosting my confidence on this one would be much appreciated.
Thanks David
Thanks David
