Yep it did. Bathroom sink not draining down. The sink is pedestal mounted with the usual rats nest of pipes plug up and down thingy and no room for human hand.
Anyway its a rented property and not wanting anyone to come out in the current clime crack on and get the waste trap off, empty of whatever shes put down there back on.
Get the thing off finally not much in there to be fair. Straight out of the waste a 90' glued together 32mm waste disappearing off down into the HOLLOW pedestal.
So cant get anything down the waste to probe so put the waste back on and give up. Yep waste falls down inside pedestal,
Cant get hand in because theres access at top third of pedestal but not at the bottom.
Looking down the plug hole the waste can be seen nicely stuck.
So off with the sink. Where are the bolts holding to the wall. Surely its not being held by silicon on the pedestal. No its not its got silicon all over the back sticking it to the tiles.
B*llocks.
So get the carving knife and start trying to cut the silicon away. Goes o.k , the corners seem free lets put a screwdriver in there to increase the gap.
Why has not one but two large chips detached themselves from the top edge of the sink.
Anyway after several hours cutting away at this stuff I sense a weakening. Using all main strength and risking a stroke I managed to wrench the sink from the tiled wall, almost, a large section of the tile came away from the wall still attached to the sink, but hey its off.
Lets now enter into the world of find a way to repair two large chips in the sink.
Christ how much, what if it doesn't go well should I use the money to get a new sink
Lets now enter the world of hunt the sink. I found a sink, it looks just the same, its 500mm across, the one off is approaching 600mm. Have sinks shrunk in the last ten years?
Anyway please look at the sink on the link. https://www.plumbworld.co.uk/park-lane-ryther-full-pedestal-500mm-1-taphole-bathroom-sink-6084-25707
If you recognise it from ten years ago and know who made it please please tell me who and more importantly where I can get one from.
Buy the smaller sink and say its always been there your honour.
Well yes apart from the tile without a center which that part isn't a problem the problem are the several cracks radiating out which although covered by the original sink would be some what noticeable to even the most careless letting agent.
Unless you know where I can get a replacement tile, grubby off grey...
Paragraph spacing added by mod.
B*llocks.
