Jaguar 23kw bundy tubes
7 Dec 2009
Dorset
My Jaguar 23kw boiler stopped producing h/w. An engineer came out to look at it, said it could be a load of different things and would probably cost in excess of £500 to fix. So looked on this site and everyone pointed to it being a problem with the daiphragm so took the plunge and took it out.....extremely happy to find yes the diaphragm had perished so got a new part for £10 put it all back together feeling very pleased only to find that the two bundy pipes into the value which use a o ring and spring clip mechanism leak. Tried everything to stop the leak but so far to no avail...am going to order new o rings (though they seem fine) and new clips - its a full on leak not just a drip, could new clips make all the difference?
26 Oct 2007
Kent
New o rings are more likely to cure it than new clips, but both would be a good idea as they are pretty cheap.
26 Jun 2004
London
If you have a problem to get them order as Biasi 24 s Prisma.
The question is why was your man so bad?
Tony
7 Dec 2009
Dorset
Can anyone tell me if the bundy tubes on a jaguar boiler are easy to replace. I have taken apart the boiler to replace the diaphragm and now the tubes into the brass valve will not seal back up with the o rings and spring clips. not sure if the tubes might have been damaged on removal and need replacing but not sure if this is a job for a amateur?
26 Jun 2004
London
A common error is to push the clip in when the tube is not fully inserted so that the clip damages the "O" ring!
A temporary repair can sometimes be made by wrapping PTFE tape around the outside of the "O" rings.
Tony
