Hi there all, first post so please be gentle.
BACKGROUND:
I am a new homeowner and trying to do a few jobs myself, due to current financial obligations. I had a subcontracted plumber come in to do some work in the bathroom when my place was renovated some time ago, and one of the jobs he did was change the bathroom taps. Only long after he had left did I discover that the hot and cold supplies were reversed from the normal sense (ie: hot on the right tap).
The supply is currently connected from the copper pipe feeding the bathroom, to the taps, via JG Speedfit Flexihose pipes, like these:
http://www.speedfit.co.uk/Home/Prod...2---28mm-Size-Hoses/SPEEDFIT-X-UNION-NUT.aspx
The connection from copper to Speedfit Flexihose is under the bath and can be accessed relatively easily via a 'removable' tile on the side of the bath.
PROBLEM: I want to reverse the hot and cold supply connections, so that the sense is correct at the bath taps. Unfortunately, the currently installed Flexihoses (300mm length) are too short to be crossed over and still reach the correct tap. I bought some 500mm Flexihoses to replace them, but these seem too LONG, when connected and crossed over to reach the correct taps - ie: the amount of bend required on the Flexihoses to get them to connect seems excessive.
Is there a way that I can cut the Flexihoses shorter? It doesn't seem obvious to me how I would be able to re-attach the fittings (union nut or collet, depending which end I cut).
Otherwise, can anyone suggest an alternative solution to connecting my bath taps up to the copper supply running into the bathroom? Off the top of my head, the length of pipe required for each connection would be about 400mm.
Thanks in advance for your help.
BACKGROUND:
