In Scotland is it legal for a joiner to do electrical work?
all depends on whats being tackled some is controled and requires notifacation other work is fine
Puffin, you might have had more info from posters if you asked for this to be moved into the Electrics UK section. I'm sure when I last checked Scotland was still part of the UK.
Am I right in thinking you paid for professional electrical work which was completed by a joiner but that the firm who provided him said that a building warrant was not required?
Either way, whether the joiner was competent or his work was being overseen by someone who was competent, you should have still been provided with an Electrical Installation Certificate with reference to BS7671 in addition to whatever was required under the building warrant scheme.
Puffin1,
follow this link www.scotland.gov.uk/resource/doc/217736/0098173.pdf
This will take you to the list of non notifiable and notifiable works.
Anybody who would use a joiner, kitchen fitter anybody not a TIMESERVED electrcian needs their head examined.
The company you were intially going to hire...tell them to beat it as any REPUTABLE firm would know of the requirements.
You have been warned!
Puffin1,
Many thanks for your reply too.
I had a snagging list done by a professional property and construction specialist firm. They did not check the socket electrics. I had a SELECT electrician come in to see to hob and oven and he reported that there were faults but not dangerous. He did not ask about new sockets and I didn't know then to tell him. I then had the electrics all fixed by a SELECT electrician who fixed hob and oven and rewired the sockets but didn't offer any certificates but will supply now that I have asked him.
The hob and oven were not dangerous, just inconvenient that I couldn't use hob and oven at same time or have all 4 elements of hob on at same time.
But BS said I have to get an architect to make drawings. I am not sure that BS is correct. Only time I had such drawing was when I completely gutted an apartment overseas and drawings were necessary as everything was being redone, and then only necessary so that electrician knew exactly what he had to do.
Do you think drawings are necessary for putting in 2 new double sockets and 2 isolator switches??
Building surveyors know very little about a lot and not a lot about very much in my experience.
As for drawings well...what was the extent of the work being done? just a new kitkchen! then no you don't need drawings however, it is worrying the SELECT electrician never offered any, especially as he was their to put right a non qualified chaps work. It is also a requirement of his registration.
If you have had for example a extension or major works i.e movement/alteration of a load bearing structure, then a building warrant is required and the BCO will be involved therefore, electrical work should be on the drawing as it is part of the whole job.
1CANHELP-
Your first link (to the 'Works Requiring a Building Warrant') states that a warrant is required for such-and-such, now you're saying a warrant isn't required unless it's structural work . . . ?????
To the OP, If Building Control are on to you you will most likely have to do what they say and get a warrant for your work. In reality most people do not get a building warrant for things like adding a socket in a flat even though they should. You are right that it is a ridiculous situation.
If you are applying for a building warrant you will need plans (existing and proposed) which are normally done by an architect or technician.
Also there is NO REQUIREMENT EVER to use SELECT or NICEIC (the other registration scam (scheme) in Scotland) to do electrical work, paid or DIY, for building warrant or not.[/code]
We're talking council building control people here....Of course an EIC will have to be provided but surely only an idiot would assume that that you had to be registered to be competent to do that?
Care to identify which of the 500 we should read?If you care to read my posts you will see what my opinions are on DIY electrical work.
Always risky to have a dig like that....Or maybe not because you porbably would be able to spell a little better if you had been schooled back then.
....but are quite happy to wage into me with accusations of incompetence.
