doing a utility and my other half as now changed the design
orginally i was just going to have 2 pieces of worktop on the end of run base units - with full height base depth units 2m high in between
so this was asimple 600mm - just over to hang over - and that could just mean I cut one piece twice - probably a 1.8 - its comes with 4 sides edging
And have cover panels to go down the sides - so reasonably straight forward - i thought
SO now its going to be a full 3.2 M - with the same 2 base units at each end - But this time will be 5 base units - 600 + 600 +800 +600 +600
Standing on top of the worktop will be full height 1000mm 38mm deep + doors - units standing on the worktop for the middle 3 units 600+800+600
so i'm now joining the worktop
EKBACKEN - worktop 1 off 246x2.8 cm and 1 off 186x2.8 cm
white lively marble effect/laminat
i was planning to to use 1 lenght over the
600+600 - and join across the base unit join
and the other
800+600+600
i have fitted worktops in the past - but with my brother using a kitchen Jig and dog connectors , router etc
BUT - he nolonger has the Jig
I only need to join the 2 pieces together
I have a dewalt 625 router (I can get the correct router bit - BUT i think i may have one any way )
various bits in a kit
A bit from screwfix - 60+cm - kitchen
Down Shear Trim - top and bottom bearings can be removed - may not be correct bit
www.wealdentool.com
anyway - any suggestions on best way to do this without the Jig etc
I have a freud blade just sharpened for the circular saw and will use a guide to cut the two ends off to join
then I have some D4 PU glue - i used on chipboard flooring - this week, left over and could use that to join
OR ???? maybe some sort of colour fix instant glue
used this brand before
as laminate is white
Then make some dog joins - using fostner Bit and then a straight cutter to got to the edge and just do with some sort of JIG - or clamp some 2x1 onto the board
i have a cheap MFT table i purchased a few weeks ago on offer - so with saw horses could clamp the worktop on that and then clamp down and just router across the two pieces
as i'm typing this thinking that maybe the way to go
BUT as i do - I dont want to over think
not much w/top on show
wall units about 40cm from wall
so 20cm deep along 3 base units will be on show
and the other
800+600+600
Down Shear Trim
