The walls of the kitchen at the corners are way out. 75mm over 2 metres.
I thought of using 900mm worktop and scribing to get it at 90 degrees without going under 600mm so that units fit correctly.
I was then going to buy an extra large jig and end up with a much wider worktop as I thought the extra space would be handy.
Do the jigs accomodate all increments between 600 - 900mm or do I have to aim for a particular width.
Is this the best way of joining corners or could I mitre an angle over 90 degrees and just use dog bolts
