joining ridge and hip tiles
3 Mar 2008
Gwynedd
I am fitting the ridge and hip tiles ( Marley Modern) to my extension with dry fitting kits which come with instructions and really do seem convincing.
Unfortunately the instructions don't cover what to do when the hips meet the ridge. Nor can I find a special kit for this joint.
Is there a standard way of making a properly weathered 3 way joint?
Its a bit of a problem for them to solve with all the different ridges available you can get a stick on lead flashing in different colours, have a look on you tube.
As above. They usually customise such fittings for own make only.
When i've run into flashing difficulties esp. at this saddle position, i've bossed a piece of code 5 sheet lead into position - very little of the lead is visible from below.
Marley tech dept will surely have an answer?
