No electrician wants to take on the job to fix my ceiling light, so I need some advice please on how to do it myself!
Long story short, I need to join back the cut ends (core wires? Neutral and live) back together after a friend (electrician) cut the flex which feeds power to one of the ceiling light's 'arms'. The problem we had before turned out to be simply that the cheap bulbs I was using kept exploding!
So, anyhow, what do I use as I am confused between the permanent flex connectors ( I'll need two I guess) or the choc-blocks (our friend connected one end of the two wires to one of these) I assume the latter is for a temporary solution or am I wrong?
Any advice is appreciated and any electrician around the croydon area willing to to do this small job would be appreciated even more!
