Jointing compound for panels
26 Mar 2010
Birmingham
What would people recommend as a jointing compound for wings? Got a 2ndhand wing I wish to fit, and dont want to use anything too permanent in case it ever has to come off (one car I wanted to take old wings off were STUCK on- removed all bolts, inserted variously screwdriver/ chisel/ crowbar- dunno what theyd used but as good as welded, it completely distorted wings and still they wouldt budge- not 1mm!)
Anyway, I just want something to fill/ waterproof the joint, nowt that strong please!
Ian
You should have tried a cheese wire or similar tool like they use to remove windscreens to break the seal on the old wings. They are usually fixed on with body caulking which comes in strips like plasticine and that is the best thing to use Lay it between the inner and outer wings and you have plenty of time to readjust them if need be
