Below are extracts from a SE plan. I'm planning on doing the work myself.
I have some basic questions.
For reasons, I can only get 75x200mm C24.
1. Are 47x97mm (2x4) wall plates going to be big enough to secure 75x200mm (8x3) hangers? What size wall plate would you suggest for combination?
2. Can you suggest a suitable hanger for the suggested wall plate size?
3. Can you suggest suitable nails for the hangers?
Bonus points for links to a place I can buy them online...
Thank you
Wall plate
Use min 47x97mm C24 grade timber as wall plate. Wall plate to be anchored to Wall using 1 M10 resin anchor at 400C/C. Anchors to have min 90mm embedment into masonry
Floor Joists
Use min 63x170mm C24 grade timber at 375C/C.
Floor Joists to be hung from galvanised hangers.
Thank you
