- Joined
- 22 Jan 2021
- Messages
- 116
- Reaction score
- 1
- Country
Hi All,
Picture attached of the setup I have for my fireplace (blocked up and not in use). Apologies for the dodgy powerpoint plan!
I'm replacing the joists/wall plates in this room and wondering if there are any requirements about how close the wall plates/joists can be to the concrete blocks under the hearth?
The closest guidance i've come across is '40mm from the outer surface of a masonry chimney' for combustable materials (except skirting etc). I'm not sure what constitutes the 'outer surface' of a masonry chimney when the flue/recess is behind a wall running straight across the room, or if the concrete blocks making up the underside of the hearth are considered part of the outer surface, so I have to leave a 40mm gap to these?
