junior 28i
I think that you misunderstood WB. You can't adjust the hot water temp this is preset. Your problem was modulation which you have fixed.
i asked was there anything i can alter or check to help my problem and they replied check the thermistor.if that was o.k id probably have to put a blending valve on the system because everything else related is factory set.
