I have just moved into a flat and there is no timer for the hot water. I feel that it is a waste of money if I leave it on when I am not there. Am I wrong?
My flat has an immersion heater, storage heaters and underfloor heating in the bathroom.
The boiler has two electric cables, one coming out top and one the bottom of the boiler and they go to two switches which have a red neon light on them. The top switch works and produces hot water quite quickly but the bottom switcn does not work as the neon light does not come on and does not seem to produce hot water.
A friend said the top half of the boiler is usually used for some kind of boost. The previous tennants said they left the working switch on all the time. So did they leave something on all lthe time that is just suppose to be used as a temporary boost?
There is some kind of digital timer from a company called WARMUP but from what I can work out it is for the under floor heating only?
Could someone please recommend the most efficient way to use my setup please.
Lee (no heating skills since birth!)
