Kahrs Woodloc 5s- cut out and replace board
10 Oct 2018
I have a Kahrs Woodloc 5s engineered wood floor, it's very good except in one location at the end, where it is a bit bouncy. I think the concrete base was not completely flat here and has a dip.
I was thinking of cutting out a board, building up the subfloor, and replacing with a new floorboard. There are instruction on how replace a board on the Kahrs website, so it should be possible.
Does anyone have any experience with doing this? Is the replacement board at all compromised?
5 Nov 2007
Depending on how deep the dip is, adding underlay might suffice. You will have to take up the flooring from the nearest wall or other boundary, so potentially quite a few boards. Kahrs and other manufacturers change the width of their engineered boards from time to time so make sure the replacement is the same width, most suppliers will provide a sample board.
Blup
10 Oct 2018
The board I want to remove/replace is short and at the end, which is convenient. I also have extra boards from when it was laid, so should be ok with the width.
Have you experience with cutting out and replacing woodloc 5s boards? Are the replacement boards compromised at all? Do they ever come loose or come unglued? I'm trying to decide what's worse- living with the springy board, or living with a repair job?
