thanks for the offer of a couple of beers and lunch in a previous post but at this rate i will be looking for a nice holiday ! LOL
(all your questions will help others also so keep them coming)
When using carpet as a template, depending on how new it is and how well it was fitted it will of been stretched. The carpet can change its shape by the time you get it up and try to use it as a template. Also there should be some carpet tucked down the back of the gripper so it will be to big, so you think maybe i will allow for this and it still dont fit as the fitter never tucked the correct amount. Also different pile depths will change the size of your template! Do you go by the pile on the edge or the backing? It will be different depending on who fitted it.
Give it a try tho! its only plywood that can be replaced if it dont fit! I just find it easier to make my own template that i know is accurate and it takes under 5 minutes for the adverage bathroom to make and maybe 30p of paper!
As for lifting floorboards? You only need to do this on loose boards that need screwing down, If your using the correct staples (18-23) plus your 6mm plywood you will not hit a pipe! The only way you can hit a pipe is if the plummer has notched the back of a floor board! You are working to british standards with them staples and thickness of plywood. For one of them staples to hit a pipe means the plummer never worked to British standard and there workman ship is below standard and their problem to solve/sort out.
as for fitting vinyl, well its not something you will be able to do straight off. You only get one cut, its not like karndean where you can replace a tile if cut wrong, i would advice another course before you try and free hand the stuff!
However you can use your template. Even i template some vinyl jobs if there large and complicated (so dont think im saying this because your a novice). BUT you need to know how to template properly for this! When i say complicated i mean running through a few door ways in one when your very tight on width etc. But still, if you was my apprentise who has been watching me fit for the last few months, i would still make him template a 2x2m room (as this is the correct way). Plus if you was fitting LINO in a bathroom the ONLY way to fit it is to template.
So do you know how to template properly? In other words, cut your template paper short by 1" and use rules and a pencil? I can send you a video of someone doing this but will need to get permission first.
Also vinyl needs to be cut about 2mm short as its loose laid not glued. The vinyl will grow and shrink with heat. You cover the gap with silicon.
add me as a friend and i can P.m you the other question.
