Keen to learn a little about Electrics
  • Thread starter Thread starter undertrained
  • Start date Start date
Err, no I don't. I am qualified in gas and have my essential electrics qualification.
The power supply to any gas heating system requires a 3Amp fuse and all wiring should be minimum 0.75mm2 , all controls must be taken from this single source as well as the appliance, this is to have only one point of isolation, so you dont get alovely surprise when you isolate at the fused spur then find out some idiot has put something on the circuit connected to an external plug.
As you state, you are in full time employment, so what does a 'greater understanding' offer you? Knowing how to do more electrics does not give you any further outlets without more registration and the attendant expenses.
I have worked in oil heating and resisted the overtures to include gas work. There are only so many hours in the day, and if you are fully employed, why incur all the extra costs for no more reward?
Thanks to all who have provided a decent reply. Ian has provided me with the answers I was looking for.
The point being that to progress in electrical installations you have no choice but to pay the money, get the qualifications and buy the test gear.
I wanted to know more on fused spurs,
I presume you mean Fused Connection Units. The cable is the fused spur although a lot of people, including suppliers, make the mistake.
running cable,
https://www.diynot.com/wiki/Electrics:walls
cable sizes,
The cable which can carry the required current.
Fused Connection Units have a maximum 13A fuse so 1mm² (or larger) T&E or flex will suffice.
Ones for a boiler will have a 3A fuse so virtually any cable will be satisfactory.
If installed in thermal insulation a larger cable might be required so don't install it in thermal insulation.
clipping distances, etc.
Common sense.
Fire resistant clips are now required if it could fall in a fire.
One example might be how many live, neutrals and earths can be fed from one spur?,
As many as will fit in the terminals, I suppose, but because of the fuse limitation more than one, maybe two, is unlikely to be required.
for instance boiler, condense pump and room stat?
Well, they will be wired from their control points (or perhaps via a wiring centre) so the question does not arise.
Is it a case of applying ohms law?
Ohms law is important but I don't know if it is relevant to anything you have asked.
3kW @ 240V immersion should be P/V=I (P is power {Watts}, I is current {amps}) 3000W/240V=12.5A but
that is because the element has a resistance of 19.2Ω which is the only constant value so at 230V it will be V²/R=P; 2760W and 12A.
Calculator https://www.tlc-direct.co.uk/Technical/Charts/OhmsLawCalculator.html
Are there any books on this?
Lots - search for electrics for beginners. Make sure it is British.
A good author -
https://www.amazon.co.uk/Electrical-Installation-Work-Brian-Scaddan/dp/008096981X
I don’t want to purchase the 18th edition just for a small section,
is it worth purchasing the 17th 2nd hand?
Yes, it is more or less the same and will contain the Current Carrying Capacities of cables, Installation Methods etc. plus a lot of rules.
https://www.amazon.co.uk/Electrical-Installation-Work-Brian-Scaddan/dp/008096981X I don’t want to purchase the 18th edition just for a small section,
A copy of the Regs makes for some very dry reading for the best of us, hardly suitable for an absolute beginner. Better if he concentrates on basic circuits and how they work, before progressing onto the Regs. He can always then refer back to the Regs if he needs to, or ask on here. I remember studying them whilst at college and committing them to memory, including many of the more useful tables.
I’ve been doing some wiring of boilers and room thermostats for a while now (like for like, or an easy wireless stat). I wanted to know more on fused spurs, running cable, cable sizes, clipping distances, etc. One example might be how many live, neutrals and earths can be fed from one spur?, for instance boiler, condense pump and room stat? Is it a case of applying ohms law? Are there any books on this? I don’t want to purchase the 18th edition just for a small section, is it worth purchasing the 17th 2nd hand?
Any thoughts, comments or answers greatly appreciated.
Tia.
Might have been good idea to learn first
Apprecentiship sonnyjim..or training courses.
you might have been lucky enough, to get an apprenticeship and train at others expense , unfortunately not everyone has that luxury these days and someone trying to better him or her self by asking for help should be supported, not ridiculed by self important idiots like you, glad you got everything handed to you on a plate and to be honest reading some of your comments you were not paying attention , you know feck all
