Hi All,
First post on a forum so please bear with me.
We have a 11 year old Kinfisher MF mains gas floor mounted boiler in the garage attached to the house and over the last couple of years the boiling (kettling?) has gone from intermittent to near on every morning and evening, our system is as follows:
Kingfisher MF
Gravity System
Pumped CH
Cylinder in A/C with no tank stat
Drayton Stat on pipe in garage (is this for CH or HW?)
Frost stat in garage
basic 7 day programmer for CH & HW
HW comes on when CH is on. HW can come on independantly.
Radiators with TRV other than bathroom rad
Thermostat in hall
The symptoms are as follows:
After running for 20 minutes the cylinder, boiler and pipes (presumably) start to really bang, if the boiler is left on the loft fills with steam which I guess is from the water expanding in the cylinder and being ejected into the loft expansion tank. It can be really violently noisy, so noisy that when stood next to the boiler you can hardly hear someone speak and it sounds like a club hammer being smacked against a scaffold tube as hard as you could possibly hit it!
The thermostat knob on the boiler seems to work as it shuts off and restarts the boiler when turned up/down. Although we don't really know which 'dot' to set it on as there is no temp shown on the boiler faceplate or in the instruction manual.
I've had a word with Potterton tech and they suggested changing the overheat themostat and thermistor which we did but this has not cured the problem (should i have used new thermal past when fitting the thermistor?)
They said if this does not do the trick then its the main pcb that needs changing but I don't want to if this will not cure the symptoms.
We're guessing the problem must be with the HW only as the CH has been off all summer.
We also have an issue with the hot tap in the downstairs loo that sometimes runs for a minute or so before the flow goes to a trickle then stops. All other hot taps in the house are ok, would this indicate an airlock of some description?
We've been in the house 7 years and never had any maintenance on the boiler or HW/CH system.
Apologies for 'War and Peace' above but have tried to think of all the info needed for a bit of advice.
Thanks in advance
Steve
Kingfisher MF
Gravity System
Pumped CH
Thermostat in hall
Thanks in advance
Steve
