Hi Gents.
Just joined and have read with great interest all about appliance installations.
I am about to start fitting a new kitchen with all new appliances and a change from Gas to Electric. I 'believe' I know what is required and I will be using a professional to do the wiring in of the new appliances but I am interested to know if I have the right idea (so I don't get fobbed off).
I have checked the Consumer Unit and there are 2 spare/unused slots with blanking plates over them so I have no worries there. The distance from the Consumer Unit to the appliances is a maximum of 4 metres of cabling, and there are no thermal insulation issues.
Appliances as follows:
Combination Microwave/Oven - rated @ 3.6Kw
Oven - rated @ 2.9Kw
Hob - rated @ 6.8 Kw
The Microwave & Oven are to go into a tower unit and I expect these to both be served from a 32A MCB to a Control Unit to an Outlet Box and then to both appliances, using 6mm cable all the way through.
The Hob I expect to be on a separate 40A MCB to a Control Unit to an Outlet Box and then to th appliance, using 10mm cable all the way through.
There is also a Cooker Hood, which will run from a fused spur from the ring.
Does all this sound about right.
