Can't see any obvious ratings, this is a cooker hob combination being replaced with a standard single oven and a separate halogen hob. Separate fuse at fuse box rated 32.
Other treads are inconsistent in the advice some say separate some don't. Is a separtate another wire run from the fuse box or a separate spur from the origional.
