Hey,
Is it possible to get hob/half height style ones, rather than full height.
I have a touch of the stairs creeping into one corner of the kitchen which stops me from using a corner unit, so I thought about building out the wall enough (maybe 200mm) under them to enable me to use a corner unit.
I'd only make the wall the same height as the unit so the worktop still goes all the way back.
One concern with a full height unit is it would stick out too much and most likely render the worktop unusable.
The only other thing I can think of is use 2 hob units to make a corner, but obviously the actual corner will be inaccessible.
View media item 61318
This is the other leg of the corner unit. The 300 wall unit will be bought forward as well to line up...
View media item 61319
