- Joined
- 11 Jan 2018
- Messages
- 9
- Reaction score
- 0
- Country
We have just had a kitchen fitted and are not happy with the finish. One of our corner units does not sit square to the wall and therefore the larder next to it doesn't either (larder is approx 10mm away from the wall on one side).
Two worktops do not sit parallel to the wall - one has a gap from 0 to 15mm over 2.5m, the other 1-2mm - 10mm over about 900mm.
One of the worktop joints is not at 90 degrees its about 2mm off of square between the front/back to the worktop. This is resulting in the worktop moving away from the wall (by our calculations by about 6mm at the far end where the gap is currently 15mm). The overhang at the front of these cabinets is also not the same all the way along - being 49mm one side and 56mm the other.
The kitchen fitter is telling me is due to the walls not being square and we need to build up the plaster / tile to over the gap. He is saying they have done nothing wrong and it couldn't be fitted any better. He is also denying that the corner is not at 90 degrees even though the set square proves it is not at 90 degrees. To this he said i couldn't expect him to be more accurate than within 1-2mm of square.
We have discussed these issues with him but he doesn't seem to agreed that the fitting is at fault, but is just blaming the walls. We have tried to explain that if the cut along the worktop join was square or 1-2mm in the other direction most of these issues would be resolved. He has stated his cut is square (even though it is not) and that you 'wouldn't' ever cut to slightly off 90!
Is this actually an acceptable standard? am i being unreasonable to say this is not up to scratch?
Also how easy is it to correct these issues? how easy will it be to get the worktops apart? He tells me he glued them, which is also a concern as i didn't think you should use glue on wooden worktops.
