I`m a bit confused here as i had a few electricians around to quote for the electrics for my kitchen and most of them ( not all ) said that the wiring is not correct to install a electric hob and a single oven. Taking in consideration that the cable from the old cooker is 6mm cable connected to a 40 fuse.
Some say that i will require to change the 6 mm / 40 fuse to a 10mm / 50 fuse and connect both the hob and oven on a single fused spur.
Some say that i can use the 6mm / 40 fuse for the electrical hob and for the single oven just connect to a 13amp fused spur from main ring.
Are any of the above or both of the above correct / wrong ?
The electric hob full power consumption is 6.5kw / 1200 w
The electrical single oven full power consumption 2.7kw / 780 W
Took the above facts from the tech spec of the appliance.
Thank you
Thank you
