Kitchen light keeps going on and off
22 Nov 2018
My kitchen light sometimes turns on and sometimes doesn't. If you push where arrow is it might come on. Is this a loose connection? How do I fix it?
Most common fault with ES lamps is a poor connection with either the bottom or side terminals, try some contact cleaner or physically bending the terminals.
Have you got a halogen bulb you can try? Lots of cheap Chinese bulbs don’t connect well either
I would start by checking the connections are tight, pushing the lamp holder would flex the wires, which may make it seem like that's where the problem is.
