The leaking is pretty slow all the time but increases slightly when either of the hot or cold mixer taps are turned on. The leaking is gradually getting worse over time.
The leak is not at the point where the swivel head is mounted rather at the bottom of the body of the tap itself so is flowing directly from the base of the tap onto the sink surface ( it seems to be seeping directly from underneath the tap housing where it meets the kitchen sink).
The tap is a Kludi mixer tap with a swivel head.
Any pointers on how to fix this would be appreciated - is it likely the mixer at the base of the swivel head? This would not make sense to me as the leak is not at this point of the tap (the swivel head sits on the tap base which then connects to the sink)
