Kitchen spotlights
sorry taylor.i'm a bit confused.your saying that each dimmer is 150w....times that by three and it makes 450.so why should a 250 w dimmer be ok?
I had understood that you wanted to conbtrol each of the three banks of lights with a separate dimmer.??
If you want to do that you need a three gang dimmer with each gang rated at 150watts minimum.
If you want to control all the lights from a single dimmer then add up the wattage of all of the lights and get a dimmer that is rated at least as big as the total.
TTC
Yes I did say in my original thread I was looking for a triple dimmer switch. So what your are saying is a 1way 3x250w switch would be ample. Thanks very much for your help Taylor
