kitchen under cupboard lights
14 Mar 2008
Nottingham
hi new to this forum but thought i could get some help i am fitting under cupboard light s and want to know if i can fit them to an exsiting socket on the wall the socket has 2 blank switches and two live switches 1 for freezer and one for dish washer so can the lights go in to the blank also where would you hide the transformer as i don't think it would look right under the cupboard any answers
Right, firstly, dont fit halogen lights under the cupboards. They are too close to the surface to produce any useful area of light.
Secondly, why are you bothered about what looks right under the cupboards? You wont be able to see it (unless you're a dwarf?) so it wont matter. Go out and buy the ugliest fluorescent strip lights you can see. These DO provide very bright and useful light.
Also, can you post a picture of the accessory you describe on your wall, I cant picture it.
thanks for the reply steve not really bothered if the lights are not that bright as they are mainly for show, as foe the switch its a normal white switch socket but has two blanks and two live switches i was told i could take the blanks out and add switches for the lights
So you have
With 2 x switches
And 2 x blanks
Or is it a different design?
Anyhow, you can remove the blanks, but you will need a fuse module and a switch as well. Lucky you have 2 blanks eh? :wink:
And its odd that the spark fitted a 4-way grid plate, when only a 2-way was required. Any reason for this that you know of?
the pics are pretty much the same just on the live switches it has freezer and dish washer written on them i presume its so you dont have to pull the appliances out to switch them of as for why 2 blanks i counn't tell you already there when we moved in also when you say fuse module what is this not to gend up on electrics still learning lol
Sounds like 20 a DP switches were used
Possibly twin box used to provide more room for wires
Is it spaced sw / blank /sw / blank or similar
One fuse module :lol:
You'll need this to fuse down to supply the switch and lights. You can probably supply it as a spur from one of the existing switches (live side).
While you're shopping, buy a secret key switch for the freezer. This will stop stray hands from accidentally defrosting the freezer. :wink:
Supplied with a couple of keys.
All available from http://www.tlc-direct.co.uk/Main_In...nu_Index/Grid_System/Grid_System_3/index.html
If it is this design. Luckily that site has good photos, so dismantle your current switch and see if the modules are the same design.
thats good to know i can spur it cos i was hoping to put the plinth lights in the other blank do you think this will be ok
As I said, to supply one set of lights, you will need two modules - a switch and a fuse. You could use the same fuse module to supply the second switch for the plinth lights, but you dont have space on that grid for another switch. You can use the same switch though if you wish, or have a seperate switch plate altogether.
Alternatively, buy a 6-way grid plate, but these are twice the size of the 4-way. If, as rocky mentioned, the 4-way was used because of lack of space behind, if may become nessecary to use a 6-way anyway, to be able to fit everything in behind.
If you want to be really fancy, and your lights are compatible, you can buy grid dimmers. :wink: See that site for details.
