Hi - I'm planning a kitchen with DIY kitchens, which I'll install myself. Over my hob I have planned a 600mm wall unit to house a canopy extractor and this is 68cm above the hob. I have a 450mm wall unit either side, which have 530mm clearance from the countertop.
I want to add panels under the wall units either side of the hob and up the exposed side (see pic). The panels are 18mm think. DIY have flagged this up saying that the panels on the sides, facing the hob will be affected by the heat from the hob. It's an induction hob although of course there'll be pans steaming away on it. The hob is 590mm wide. Are DIY being over-cautious or will the fact that my panels encroach 13mm over the hob (and at their lowest point 512mm above the hob) be an issue? I've shown the position of the panels with diagonal lines in the pic. Thanks for any advice.
