knock through
27 Aug 2012
Liverpool
hi, im due to do my knock through, got my steels and bolts. was measuring were the steels are going and noticed the external skin is normal brick and the internal skin is a terracota coloured blocks,the sort the spanish use. my question is. will they complicate the nock through :?:
By terrracotta block do you mean the extruded clay block used in many houses between the Wars?
If so, they will be hollow and this may present problems in supporting the inner beam. These blocks usually have thin walls (around 1" or less) and may not be suitable for supporting a point load from the beam.
If the worst comes to the worst, you might need to re-build a small amount of blockwork each side of the opening, in normal solid block, to form a bettr bearing for the beam.
that sounds like them tony. so basicly i just need to a good support on them ie a decent padstone or some engineerings. would have to be the inner leaf of the wall wouldnt it. so strong boys on acros will be enough support for the clay block. just got this vision when chopping out for the steel they will come tumbling down lol,with them being hollow and light.
