I'm about to put a hole in the rear wall of my garage for a door into the garden and wondered if anybody would like to give me some advice on the do's/dont's and anything else you can think of...
The garage is about 6 months old (new build house) and I have the complete door & door frame ready to go - just need to cut the hole.
The rear wall is not supporting any load what-so-ever (there is an inch gap from the top of the bricks to the beam) so I haven't got that to worry about. The wall itself is a single skin brick wall, with a DPC about 2 bricks higher than the garage floor. There is a block pillar (from what I remember is supporting the beam) in each of the corners of the garage to which the wall adjoins.
My current plan is to take an angle grinder with diamond disk and cut a hole in the wall just bigger than the door frame. Put door and frame in wall, screw frame into place (the side with the hinges will be screwed into supporting block work pillar), and then re-point the wall to finish off.
When cutting the hole, should I go down to the DPC and sit the door frame directly on top of this or go one brick higher?
Although I plan to be highly accurate with my hole cutting I know that the hole will not be perfectly square. How do I ensure that the door is hung correctly? The door & door frame came together and the door is pre-hung in the frame and of PVC construction.
Obviously I'm not a builder by trade, but I'm also not a complete building novice. Unfortunately all my building experience is in constructing agricultural outbuildings, and these did not need to be presentable - where as this does!
Cheers,
Rich
Cheers,
Rich
