I have gone over the Knots with 2 part wood filler then primered the whole gates with 2 coats. I have rubbed it all down with a wire brush and the primer hasn't been disturbed, holding up well.
Going to dry them out for a week, as been bucketing down here, then an oil based primer , then Superdec. I assume when it has been gone over with a wire brush and Power washed it will not need sanding again?
You can sand if you want to. My assumption is that it is the job of the primer to stick to anything.
If you power wash it, that's same as pouring rain. Then you have to dry another week. What I do is clean and tidy first, then paint with undiluted bleach using brush. Once dry wipe with damp towel. Then dry, prime, and paint.
