The system is working "ok", but I know not optimally. The problems are / were:
1) that it takes a long time to heat up. This became more noticeable as the outside temperature dropped.
2) if downstairs and upstairs zones are both open, the upstairs only gets warm. When downstairs zone closes, upstairs gets hot.
3) The upstairs zone is ~ 18KW (rad output), downstairs ~ 26KW, and HW zone is a megaflow indirect 250L (26KW coil I believe). I was finding that the HW zone alone would cause the boiler to cycle before the cylinder satisfied it's stat.
4) The downstairs radiators would only get hot at the top, and lukewarm in the middle, almost cold on the bottom. All are new rads as of a year ago, and all are fairly large.
To begin with, I was getting S53 with the boiler not range rated. (Boiler is a Vaillant 438). To resolve this, I range rated boiler to 18KW. This was to remove the S53 and to resolve (3) above, so the cylinder heated up without the boiler cycling.
Another problem I had was a faulty / stuck ABV. This was continually allowing water to flow. I have since changed this, but I must admit, even now, with only the HW zone, I can feel the bypass pipe getting hot. I dont know if this is just due to convection in the pipes, or if the ABV works gradually, allowing small amounts of water to pass. The ABV is a honeywell, and the setting is now 5.
As of a couple of days ago, I've range rated the boiler to 26KW. I think this has helped in solving (1) and (4). I'm not sure about (2), have yet to test.
(3) has been an interesting one. Initially, when I went to test the HW alone (this is when the tank was probably already almost up to temp), I found the boiler started to cycle almost instantly. The return temp would rise very quickly, and then the boiler would turn off. This was not happening in the first 50 seconds - I.e. the boiler should have had sufficient time to modulate down, but because the return temp was rising quite quickly, it was eventually turning off and cycling. The HW stat did not reach temp for at least 1 to 1.5 hours. I tried adjusting the ABV a little higher, as I suspected water may be passing through it, and causing return temp to rise too quickly. I dared not go past setting 6 in fear of breaking it, so eventually just put it back to its original setting. I tried adjusting the single radiator on the HW zone, increasing flow to it and reducing flow to it. Basically, nothing worked. So I left it.
Then the following day, I decided to monitor the boiler as the HW came on, probably from a much lower temp, as we'd used plenty of hot water. To my surprise, the boiler behaved much better. Initially for the first 20 or so minutes, it increased flow temp slowly, and return temps also crept up slowly, with a differential of about 12 degrees. As the boiler reached max temp (70 degrees), it went very, very quiet. At first I thought it had gone into S53, something Ive seen a lot of, but in fact, it was still running normally, it had just modulated down so much, it was barely making any noise. The return temp was 65 degrees at this stage. The boiler continued firing at 70 for about 10 minutes, and the cylinder stat switched it off - a total of 30 mins, which is what the Haetra Sadia literature says the recovery time should be !
So the long and short of it is that I think the system is working pretty well now, but I need to monitor for a week or so. I think the boiler behaves well in certain conditions, but can sometimes get itself into a state where it results in cycling or S53. Perhaps the new PCB would help, but Ive thus far been unable to get one. I've asked Vaillant about it, but they've not been very helpful. I live in SE London / Kent by the way.
With regards to (2) above, I have a secondary pump on my downstairs circuit, as the last rad was not heating up. I have a 26-55 main pump, then a 15-60 second pump on downstairs. I feel the entire system should probably have a 25-80. Probably a grundfos alpha smart pump, because it could adjust the pump speed accordingly if one zone or all three zones are open. They cost over £400 though, so Im reluctant to invest in one unless Im sure it will help.
Sorry for the long post! Wanted to try and be thorough.
