- Joined
- 15 Jul 2022
- Messages
- 72
- Reaction score
- 2
- Country
Hi All,
I was going to ask you about acclimatisation.
The vendor says 48h but on YT the same vendor also says about the need to have radiant heating ON during acclimatisation.
I don't have the heating turned on in the house at the moment but should I do it before and during the installation?
In my case 7-8mm thick laminate floorboards.
What is the exact reason behind this process? Is this the temperature, humidity or both?
Without heating the humidity is relatively high 60-65%. If I turn the heating on the humidity will drop and the boards will start shrinking.
I reckon I want to find a sweet spot otherwise it's going to be detrimental either in Winter or in Summer.
