laminate floor in porch joining to living room floor
18 Jan 2009
Worcestershire
hi
i want to continue the laminate floor that is in the living room into the porch. at the moment the floor in the living room stops at the threshold strip but i want to continue it into the porch.
whats the best way of joining the 2 sections together?? it is the same floor so no problems in matching it up.
got some pics if it makes it any clearer....
many thanks
george
take up the metal plate and put down a laminate to laminate threshold strip.
what about the join? i have seen threshold strips at b&q. would this be ok to use and not look like a **** job??
cheers
A threshold strip! as above will be fine.
But good luck getting the old metal plate up. That plate will be fixed under the laminate flooring. If you paid someone to install the other flooring i would get the lazy git to come and remove the plate for you.
Unless you fitted yourself. :oops:
yeah it might be a bit of an ar5e job to get it up(ooer missus)try using a flat crowbar and cut the fixings that are holding it down.
luckily the nails are on the porch side so should be ok to get up i hope. and yeah i fitted it myslef!!!
will just get a threshold strip from b&q then. was just not sure if there was a more 'professional' way of doing it!!!
thanks for the advice people!!
cheers
george
the" more proffesional way" is fraught with problems :wink:
assuming its click type laminate thats not glued you simply unclip the rows back into the room untill you reach the dooor frame then treat as new install but extended into the porch
now expect 1 or 2 in every 10 relayed planks to be of no use as whole planks[dammaged]
in my humble oppinion i would not have laminate in a porch as thats where all the wetand dirty stuff is left to save the flooring in the house
I would fit the whole of the porch with a coir type carpet that you can wipe your feet on. That will save your laminate and be easier to keep the porch clean. Just the opinion of a woman who knows. :roll:
cheers everyone. after a chat with the boss i think we are just going to go for some type of hard wearing, durable carpet!!
cheers :D
How about putting ceramic tiles down on the floor in the porch? At least during the wet weather, it won't get wet and soggy like the carpet.
cheers :D
cheers :D
thats a really good idea.never thought of that!!
cheers!! :D
