Laminate Floor Underlay
Status
Not open for further replies.
20 Apr 2014
I am laying a floor in two rooms. One of the rooms has hardboard already over the floorboards to level it. The other room has carpet underlay.
As I am laying floor through both rooms will i be able to lay over existing underlays ?
What would you recommend ?
there is special underlay for laminate flooring,i would recommend using the board type which is better......ian
I have the fibre board already, just wanted to save some time and money.
I have laid boards between both rooms, and i t looks OK. Just wanted to check if you can lay laminate flooring on carpet underlay ?
:roll: Is it ok to lay laminate underlay fibre boards over carpet first then put laminate ontop. I would have thought this would provide extra insulation, both noice and heat, along with providing the floating aspect needed for the laminate :?:
____________________________
moderator
please note 17,20 & 2 which are here the post was made nearly 3 years ago
Status
