    Dismiss Notice
Laminate Flooring - Lifting at edges!
Discussion in 'Floors, Stairs and Lofts' started by Alex0r, 2 Apr 2009.
  1. Alex0r
    Alex0r
    19 Feb 2009
    17
    Thanks Received:
    Devon
    Country:
    Hi all,
    Recently laid some (expensive) LOC laminate flooring but its coming up at some of the joins (in the middle of the room! :evil: ).
    Can anyone suggest anything other than ripping it all up :(
    Cheers.
  2. WoodYouLike
    WoodYouLike
    14 Nov 2004
    7,710
    Thanks Received:
    215
    Kent
    Country:
    What is coming up, the boards or the top layer?
  3. big-all
    big-all
    12 Jul 2004
    17,916
    Thanks Received:
    1,354
    Surrey
    Country:
    is there an expansion gap all the way round the room including dooorways and radiator pipes !!!
    is there any heavy furniture at one or both sides
  4. will2000
    will2000
    13 Mar 2009
    103
    Thanks Received:
    2
    Glamorgan
    Country:
    water
  5. Alex0r
    Alex0r
    19 Feb 2009
    17
    Thanks Received:
    Devon
    Country:
    yeh theres an expansion gap all the way round. no heavy furniture.
    there boards are "lifting" or coming apart at the joins in the middle of the room.
    Is there a solution at all to it?
  6. Sponsored Links
  7. will2000
    will2000
    13 Mar 2009
    103
    Thanks Received:
    2
    Glamorgan
    Country:
    what is your subfloor? what room is the floor laid in?
  8. Alex0r
    Alex0r
    19 Feb 2009
    17
    Thanks Received:
    Devon
    Country:
    it's a concrete floor with old carpet tiles on top of that, but i laid fibre board on top of that (roughly 12mm thick from memory)
  9. will2000
    will2000
    13 Mar 2009
    103
    Thanks Received:
    2
    Glamorgan
    Country:
    you should of lifted the carpet tiles up first. if the laminte is separeting from the mdf on the board its being caused by water
  10. Alex0r
    Alex0r
    19 Feb 2009
    17
    Thanks Received:
    Devon
    Country:
    Oh dear.
    Few things - the pack said the laminate was water resistant etc. It's really thick laminate. Unless it's water ingress from underneath
    Why is it a bad thing that the carpet tiles were left down ? I thought it would help with insulation etc?
    Finally, is there ANY solution other than ripping the entire flooring up? Is there anyway to repair it / or just get 1 board out ?
  11. mattysupra
    mattysupra
    30 Jan 2007
    2,243
    Thanks Received:
    50
    West Midlands
    Country:
    post a picure of the fault please.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
