I am about to lay some laminate, and have removed the skirting board.
The skirting board had been nailed into splints of wood, which have been wedged between the brickwork, and this seems to have worked fine.
However it has been reinforced with bits of concrete dotted about, and this makes the bottom of the wall very uneven, meaning there will be a 1 inch gap between laminate and wall at some points.
Is this a problem or not, it won't be visible, but will it be stable? Also what is the biggest gap I could leave?
THanks in advance
THanks in advance
