Laminate : problem with no wall to build against
6 Feb 2009
Worcestershire
I have a new house, and having removed the skirting board, I have noted that the plastered wall does not go all the way to the wall, leaving a gap between 2 and 4 centimetres.
I have continued, using the spacers as best I can to keep the expansion gap, however many of them have simply collapsed under the wall.
Having completed my room (5metres by 4metres), I have noticed that some panels have locked better than others (some are smooth, others have a small gap between them) and in some instances I am seeing panels sliding, leaving me with 20mm gaps between panels on their narrow end.
I have laid Laminate before, and believe that I have followed the instructions, so am putting my problems down to not having a solid wall to butt up against.
I can only think of a few options ...
* Plasterer to complete wall down to ground
* Get a couple of cans of Expander Foam and use that to fill gap
* Use No Nails to stick a wood baton in place and use that to butt up against
* Nail some batons to the wall in place of the spacers and butt up against them
Does anyone have any other ideas, or is one of the above or a combination of these a good idea ???
a batton fixed to the wall then your expansion gap spacers before filling with cork strips.
Thanks badgerchief. If I create some battons, and screw/nail those to the wall below the level of where the skirting board will go back, and make them long enough that they will touch the concrete floor, wouldn't I then just need to build my floor against them ??
Why would I need battons and spacers
What does the cork strip do ??
the spacers are removed before fitting the cork the cork allows the floating floor i.e. the laminate to expand/contract without coming apart or the joints opening up if there is going to be a gap underneath the laminate where it butts up against the intended batton you may need to fill this if it seams large or a gap may appear between the floor and skirting board once fitted
a picture always helps
Thanks BadgerChief, and noted WoodYouLike.
The floor has been taken up, we have binned the roll 2mm Roll Underlay in favour of some 6mm Panel Underlay from B&Q, and we have screwed battons to the wall below the level of the skirting board.
The floor has now been relayed butting up against my Battons and has gone down a whole lot better. It still isnt perfect but I am satisfied with the result.
I am leaving it all to settle for a week now, watching for any movement that I need to correct. I will then remove the battons next weekend and replace the skirting board.
Thanks both for your help !!!! :) :) :) :)
if i`m wrong i stand corrected however they refer to a wooden floor not laminate which dosen`t expand and contract as much?
No expansion gap around the perimeter of any wood floor (or copy-cat wood floor like laminate) should be filled really. See here
No, could be because we don't do 'laminate' flooring.
But that's not really the point. Even if laminate flooring doesn't expand - and normally it shouldn't, but still can - telling someone they can fill the gap most will think it is a valid practice for all types of floors.
So, better safe than sorry in these matters.
fair comment but the question refered to laminate not a wooden floor ?
It seems we are on a quest to 'ban' the practise of filling expansion gaps with cork.
If laminate flooring would never expand why then do all manufacturers of the stuff tell you to leave expansion gaps around?
don't fill the expansion gaps, it's there for a reason! To cater for expanding floors in seasons where there is a higher humidity. Fill it up with cork or anything else and you run the high risk of cupped boards!
