Lamona 3201 Under-counter Oven
21 Aug 2020
Hi, Someone posted a thread here back in 2017 about one of these ovens (from Howdens usually) which died but where the cooling fan still worked, which is the problem that I've got. They said they swapped the fuses - I can't actually locate any fuses in my oven, is anyone able to tell me where they are located? Thanks
Yes, I have a multimeter. I've located a thermal cut-out under the top cover of the oven which shows up as low resistance on the multimeter. The only other obvious component that could have been a fuse turns out to be a thermostat that regulates the cooling fan.
No, but the light doesn't come on either so it would seem to be more than the element.
Have you checked how the circuit is wired ? I would assume the circuit needs to be complete i.e. the element heating up for the light to come on
Don't assume that it's these so called fuses, I've never heard of fuses in an oven before , test the elements and fault find the entire circuit , 9 times out of 10 it's the element that has failed it's the weak spot in an oven
Thanks for the suggestion. I ended up buying a new one but will investigate elements with the possibility of decommissioning the oven as a spare against the next breakdown. If I use a multimeter, what range of resistance should an oven element fall into when healthy?
If it is not getting hot then the element will be open circuit & it won't matter which range you choose. The same thing goes for if the filament is shorting to the casing ( inside to outside).
Just do a continuity test
