A block layer laying a foundation wall for me on Monday insists on me marking out the 4 corner levels for him. I am hiring a laser level on Monday morning, I have'nt the faintest ideal how to use it! PLEASE HELP!
depends on the kind of level you are using, i am guessing your are going to use a rotating laser, and staff??? simply set the tripod up in-between your four corners (middle) attatch the laser, level it with the three turning screws using the spirit bubble that comes built into it, set your height of one corner, move the sensor on the staff until it bleeps constantly, then simply build your other corners up until the staff bleeps constantly when they are at the right height, sounds a lot harder than it is, once you set it up and get started it is pretty much self explanatory!
