Lateral restraint straps across diagonal bracing?
22 Dec 2015
I have a small pitched roof and will be putting lateral restrain straps at the gable. The diagonal bracing gets in the way though. Can I do 22mm boards each side of the diagonal bracing and then go across all of it with the strap or should the strap be on a single piece of timber? If that's not possible, then I guess I could do another 22mm board across all of them?
I was also wondering whether I need straps where the extension (single storey) meets the existing house (two storey)? i.e. the house is opposite the gable wall, so there is only a gable at one end. The house prevents wind coming from that direction, so maybe it's not an issue?
As long as you’ve got decent length screws/nails into several trusses you should be ok just packing it out as needed
At the house end no straps, but can pop some screws through the first truss into the wall with some dpc in between
A strap has to be fitted on top of a minimum 4x1 timber which is in turn double nailed to each truss. You can pack this out as need be.
This timber should be tight up to the internal face of the gable wall or walls. You don't need straps at the existing house end.
