Lay Decking on top of Existing Decking
19 Aug 2012
Yorkshire
I have existing decking that is 3 bricks from the dpc. The decking is about 10 years old and structurally ok, the depth to the ground is about 100 - 150mm on loose stone gravel. The very occasional weed does grow through.
I want new decking near level to my patio door.
The decking boards will be run opposite to how they are currently run.
Can I lay new decking on top of existing decking or should I remove the existing decking and build higher?
It would create a horrible moisture trap between the 2 layers of boards and would rot very quickly, you really need to lift it.
