Laying a slate floor
6 Nov 2003
I have searched the forum but I am still a little unsure about the answer to my question:
I am going to lay a slate floor in my kitchen. I did this in my last house and used a sealer but I had a problem with grout getting into the slate and it never looked right.
I am worried about making the same mistakes again. I am going to lay this http://www.handyheat.co.uk/acatalog/150w_cable_mats.html underfloor heating with the therma coat sealer fluid on a concrete slab base (new build house). I only want the tiles to be warm as I have radiators for primary heat.
Now how do I ensure I don't screw up my tiles? I think I should clean the tiles with plain water and then seal them prior to laying. Then lay and grout, is this the correct way? I will be spending the money on a preium impregnator this time (used HG last time).
What do people think? Really want a good result this time!!!!
Thanks in advance for your time and help,
Paul.
go for a product i use for this jopb its called slate seal by lithofin, (other products are available) use a paint brush to put it on, then when you have laid the tiles do it again before you do any grouting, you will have no probs then.
Hi
Thanks for the reply, but I think that is a gloss finish? I am after a natural finsh....
go for the one called easy care then fella, same results as slate seal.
