laying bamboo floor
28 Mar 2008
Nottinghamshire
I have a fireplace which juts out about 2 feet into the room. Can I start at the fireplace and work out towards the other wall and work back the short distance past the fireplace so that any narrow length is against the wall not in full view at the front of the fireplace. ie can I work in reverse.
yes you can just make sure that the flooring is straight with a laser light or string line, then fill in to the wall dry then cut the boards then glue and strap up
Thanks for the reply I will do that.
The bamboo being used is 3 foot lengths, do I glue the ends as well as the tongue or is this un-necessary. What is best method of removing squeezed out PVA glue.
Always glue all the T&G's. Not doing the end bits has the risk of 'walking them open'
Thanks.
One last question: The guide says to lay parallel to longest side of room, a friend suggested if I lay parallel to shortest side it would make the room look wider, is this fact or fiction?
Depends on the dimensions of the room: very long or just a bit longer than wide?
Mostly we recommend to install 'with the light' - in the direction of where the most natural light is coming from.
Thanks, in my case that would be parallel to short side as I have the only two windows in the long side.
I will now leave you in peace, thanks.
