Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Whilst you're sorting the lead out, you could take the opportunity of using expanding foam as a second line of defence against water leaks before any sealant or finish is applied to gaps and joins. For instance seal the gap between the frame and wall with foam and then apply the bead of sealant. Fill all gaps you can see before the lead, or whatever alternative is chosen, is fitted.
