I've got a front porch that is against a rendered wall but the flashing is not correct and is leaking. Currently there is a bell cast at the bottom of the render and the flashing is just tucked up to underneath it. How should I do this properly? I will replace the lead but can I cut it into the render higher up above the bell cast? If I take the render off to cut the flashing into the bricks behind there would be a unsightly gap in the render line (it's goes up diagonally so would need to be stepped if I cut it into the brick). I don't think rendering over the lead would be a good idea to cover the gap. Easiest would be to cut a straight line in the render higher up but is this ok?
Thanks.
Thanks.
