I have a rented out property. The bathroom is upstairs and water seems to be coming through the sealant and has damaged the kitchen ceiling. I will be replacing the ceiling soon and want to fix the leak issue too. It seals that the bath lowers on the wall side, when someone stands in it. I was thinking of gluing a window PVC trim from the wall to the bath edge. This will give added angle for water to flow back into the bath and not stand on the edge. Do you guys think this will work? And would it look bad? The trims look fine around UPVC windows and I think might not look that bad.
Can you guys give any other ideas?
